Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
Portwey84
Apr 03, 2020Virtuoso
Ok, so I took the plunge and I've successfully installed the latest firmware 1.0.11.100
I skipped the v.1.0.9.88 update.I bought my R7000 at the end of January 2020, it came with v.64 installed from the factory.
I had no issues whatsoever updating to v.1.0.11.100. This was my first time ever updating the firmware on any router as previously my ISP supplied router auto updated OTA.
I decided against updating the router via the Netgear Nighthawk App. In any case, I would personally never carry out a firmware update over wireless.
This was the procedure I carried out:
I downloaded the firmware update file from Netgear support
Extracted the ZIP file to a folder on my desktop
I turned off Wireless on 2.4 and 5ghz
I disconnected all four of my ethernet cables from the router then connected the router to my computer via ethernet.
I turned off my VPN
I turned off my Bitdefender anti-virus
I rebooted the router from the admin page on my computer
Via the admin page, I uploaded the file from my desktop folder and hit the upgrade button
Router did its thing, upgraded itself from the firmware update file, took about 3 minutes and rebooted itself.
After the update I just reconnected my ethernet cables, turned on my wireless, VPN and anti-virus and everything just works.
My router admin page now shows Netgear Armor in the menu setup, but as I have a Bitdefender subscription and a VPN, I'm not interested.
I'm hoping I won't get any issues. If I do, I'll be sure to let it be known.
additude
Excellent update/upgrade.
A fine example of a pure clean upgrade.
- michaelkenwardApr 03, 2020Guru - Experienced User
Wow. Netgear hasn't removed a useful feature to make way for something it can charge for.
