Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
DoctorX
Apr 04, 2020Guide
I've update to 1.0.11.100 this morning and it seems to be stable. However, I have come across twos issues.
1) I can't seem to disable WPS. When I uncheck "Enable Router's PIN (disabled because an attack is detected)" on the "Wireless Settings" page under "WPS Settings" and then click "Apply" it reverts back to checked.
Is there some other way to disable WPS?
2) I have 200Mbps service from Comcast. I ran the same speed tests from a gigabit wired desktop PC and from a phone via WiFi.
On Wifi the test reported 237.6 down and 11.7 up.
The wired connection 136.4 down 11.1 up.
Can anyone explain why the wired connection isn't at least as fast as the wireless connection?
jerel2k20
Apr 04, 2020Tutor
I took the plunge this morning and upgraded to .100 and will see if this is as stable as .42 on my unit. Many thanks for the previous posters observations.
