Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
Miked2
Apr 04, 2020Apprentice
DoctorX wrote:I've update to 1.0.11.100 this morning and it seems to be stable. However, I have come across twos issues.
1) I can't seem to disable WPS. When I uncheck "Enable Router's PIN (disabled because an attack is detected)" on the "Wireless Settings" page under "WPS Settings" and then click "Apply" it reverts back to checked.
Is there some other way to disable WPS?
2) I have 200Mbps service from Comcast. I ran the same speed tests from a gigabit wired desktop PC and from a phone via WiFi.
On Wifi the test reported 237.6 down and 11.7 up.
The wired connection 136.4 down 11.1 up.
Can anyone explain why the wired connection isn't at least as fast as the wireless connection?
#1 - Dont see what you are talking about - I only see the WPS Wizard button (I dont use WPS, so I have not clicked it).
** Update - I see Advanced Wireless Settings - Yes, You uncheck it, apply, and it is still checked!
#2 - I have the same comcast service. On my wired connection I am getting 240 Down and 6 Up (normal for comcast). I would like your upload speed, about 6 is the best I get with comcast's Half-Fast crappy upload speed.
Portwey84
Apr 04, 2020Virtuoso
I've just done a Google search on this issue and it brings up several threads on the Netgear Community about the subject. Might be worth having a read through.
I haven't bothered to try unchecking WPS because I just manually add devices anyway.
- James721Apr 04, 2020Luminary
Yes the WPS unable to be disabled is a ongoing issue with the R7000. It's a shame they did not fix this in this latest firmware build but really not surprising. And yes having WPS enabled is a security issue but not as bad as others. But none the less how could they have over looked this considering it has been brought to Netgears attention for quite some time. Sorry folks after it's Netgear. LOL
- Portwey84Apr 04, 2020Virtuoso
Well if I've read through some of the Community posts correctly, if you turn off broadcasting your SSID, then WPS is disabled. Not tried it myself.
- additudeApr 05, 2020Virtuoso
+++ 1) I can't seem to disable WPS. When I uncheck "Enable Router's PIN (disabled because an attack is detected)" on the "Wireless Settings" page under "WPS Settings" and then click "Apply" it reverts back to checked.
Is there some other way to disable WPS?" +++
Try using a different browser like Chrome, Safari, the Nighthawk app...
- dshamimApr 14, 2020Tutor
I have been on V1.0.11.100_10.2.100 since last 3 days now -
I upgraded from v1.0.8.x
after upgrading some devices would connect to the wifi, but wouldn't run the internet
took a while to troubleshoot that as only 2 devices were not working, one a smnart tv and another smamsun s7, the rest of the stuff was fine
after that read somewhere that some firmware versions are incompatible - so did a factory reset -
after that things were fine
today however - it hung up twice - all the devices were connected to the wifi but not internet - but I couldn't even get into the admin panel - the led lights did not indicate that internet was down
had to restart the router both times to get everything working
considering rolling back to 1.0.8.x if this keep happening- spcrickApr 14, 2020ApprenticeThats the same problem with most of us. The devices would show connected to wifi but no internet access. I noticed when that happens, the light on the 5g band doesnt blink much. When my devices are working fine, the light blinks continuously.
