Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
James721
Apr 04, 2020Luminary
Yes the WPS unable to be disabled is a ongoing issue with the R7000. It's a shame they did not fix this in this latest firmware build but really not surprising. And yes having WPS enabled is a security issue but not as bad as others. But none the less how could they have over looked this considering it has been brought to Netgears attention for quite some time. Sorry folks after it's Netgear. LOL
additude
Apr 05, 2020Virtuoso
+++ 1) I can't seem to disable WPS. When I uncheck "Enable Router's PIN (disabled because an attack is detected)" on the "Wireless Settings" page under "WPS Settings" and then click "Apply" it reverts back to checked.
Is there some other way to disable WPS?" +++
Try using a different browser like Chrome, Safari, the Nighthawk app...
