Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
DoctorX
Apr 05, 2020Guide
From that article:
Since only the Router PIN method is vulnerable to brute force attack, NETGEAR recommends disabling this function to best protect your network from invasion.
To disable the Router PIN method:
- Login to the router GUI by typing www.routerlogin.net on an Internet browser's address bar. Note: Default logins are: Username = admin, Password = password.
- Go to Advanced Setup menu and select Wireless Settings.
- Under WPS settings, put a check mark on Disable Router's PIN box.
Note: If your model does not have a "Disable Router's PIN" option, uncheck the "Enable Router’s PIN" box instead. - Hit Apply button to save settings.
This is what I'm trying to do, but the "Enable Router's PIN" checkbox refuses so stay unchecked. This was working on my router before upgrading from firmware v1.0.9.34.
So I can choose to protect myself from WPS vulnerability or all of the vulnerabilities addressed in the more recent firmware revisions. Is it too much to ask to be protected from all known vulnerabilities?
Thornado
Apr 05, 2020Apprentice
Yes, I share your frustration about wireless-functions like WPS is not working as expected on every update. But so far the latest firmware 1.0.11.100 has been rock solid and I haven't noticed any major issues. Stable, secure and speed is the most important to me, and I feel the WPS issue is more annoyance than a security risk.
- Portwey84Apr 05, 2020Virtuoso
I can only agree with Thornado's comments. This current firmware works absolutely fine for me in every other respect.
You never know, someone from Netgear might be reading this thread and investigate, or should I be holding my breath on this for weeks or months?......
- shoman94Apr 05, 2020ApprenticeI agree it's an annoyance, I'm just happy that everything else is working great!
- DoctorXApr 05, 2020Guide
Thornado wrote:"... feel the WPS issue is more annoyance than a security risk."
That depends on the number and sophistication of the hackers in your neighborhood. :smileyhappy:
- ThornadoApr 05, 2020Apprentice
I do know my neighbours, they barely knows how to start a computer :smileyvery-happy:
Incidentally, Netgear have just released an update to the Nighthawk App. I have just updated it on my XR.
I have just taken the time also, to send an email to the Netgear team pointing out the apparent firmware flaw regarding the check box for 'Enable Routers PIN'
To be honest, I'm not expecting a response, but I thought it was worth a punt letting them know.
