Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
jerel2k20
Apr 05, 2020Tutor
I installed the .100 yesterday morning and about 630pm this evening we lost 5G network availability. Only 2.4G network was available. I rebooted the router and 5G available again. Same behavior with my equipment on the .88 firmware upgrade. Any ideas?
shoman94
Apr 05, 2020Apprentice
Did you restart the router before updating? Did you perform a factory reset after updating?
- michaelkenwardApr 06, 2020Guru - Experienced User
shoman94 wrote:
Did you restart the router before updating? Did you perform a factory reset after updating?If you really want to be thorough, it might not be a bad idea to:
factory reset>reboot>firmware flash>factory reset
And do not even think about restoring a saved configuration.
