Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
sinihong
Apr 07, 2020Initiate
1.0.11 lasted one day without any problem. But then it started having disconnection issue again. Rolled back to 42. I think 42 is the last stable firmware for the router.
- shoman94Apr 07, 2020ApprenticeI didn't have to reboot the whole router.... I just went in a unchecked WPS then hit apply and it cycled the wireless. It's been almost 24 hours since that reboot. If it keep happening I'll be getting a Tp-link Archer A20. I'm done running a 2 year old firmware with security holes.
- James721Apr 07, 2020Luminary
To the people that have downgraded back to .42. At this point that is really no longer a option. There are some security issues that the new firmware has patched. Rolling back is no good anymore. Maybe it's time to throw in the hat and get a new router. And i recommend it's not a Netgear. The Asus RT-AX58U can be found at Best buy fot 159.00 and this router works very well. Highly supported by Asus and Merlin. Firmware updates are frequent way more so then Netgear. Good Luck with your R7000.
