Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
dshamim
Apr 14, 2020Tutor
I have been on V1.0.11.100_10.2.100 since last 3 days now -
I upgraded from v1.0.8.x
after upgrading some devices would connect to the wifi, but wouldn't run the internet
took a while to troubleshoot that as only 2 devices were not working, one a smnart tv and another smamsun s7, the rest of the stuff was fine
after that read somewhere that some firmware versions are incompatible - so did a factory reset -
after that things were fine
today however - it hung up twice - all the devices were connected to the wifi but not internet - but I couldn't even get into the admin panel - the led lights did not indicate that internet was down
had to restart the router both times to get everything working
considering rolling back to 1.0.8.x if this keep happening
spcrick
Apr 14, 2020Apprentice
Thats the same problem with most of us. The devices would show connected to wifi but no internet access. I noticed when that happens, the light on the 5g band doesnt blink much. When my devices are working fine, the light blinks continuously.
- iFrogApr 14, 2020Guide
Is there a way I can confirm this is strictly a firmware issue vs damaged hardware? I ask because in my case I over drve the wireless radios under DD-WRT. The output power wasn't limited like it was on stock firmware and I wanted to see what all the hardware could do. Similar to overclocking a CPU.
- JWS9518Apr 14, 2020Luminary
Anyone have any clue why the apply button did not appear on initial setup with the username/password security questions with this firmware and I had to use the app instead to get past that point?
