Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
dshamim
Apr 14, 2020Tutor
I have been on V1.0.11.100_10.2.100 since last 3 days now -
I upgraded from v1.0.8.x
after upgrading some devices would connect to the wifi, but wouldn't run the internet
took a while to troubleshoot that as only 2 devices were not working, one a smnart tv and another smamsun s7, the rest of the stuff was fine
after that read somewhere that some firmware versions are incompatible - so did a factory reset -
after that things were fine
today however - it hung up twice - all the devices were connected to the wifi but not internet - but I couldn't even get into the admin panel - the led lights did not indicate that internet was down
had to restart the router both times to get everything working
considering rolling back to 1.0.8.x if this keep happening
JWS9518
Apr 14, 2020Luminary
dshamim wrote:I have been on V1.0.11.100_10.2.100 since last 3 days now -
I have found so far that hitting forget network on your devices and readding them, seems to help with connection issues for particular devices.. not sure if that is going to be foolproof, but so far it has worked. It is almost like the router sees the old connection as some kind of conflict and redoing it seems to fix it.
- dshamimApr 14, 2020Tutor
considering rolling back to 1.0.8.x if this keep happeningI have found so far that hitting forget network on your devices and readding them, seems to help with connection issues for particular devices.. not sure if that is going to be foolproof, but so far it has worked. It is almost like the router sees the old connection as some kind of conflict and redoing it seems to fix it.
Thanks I will try that - last night I did 2 things -
1- I noticed that NTP settings had an error - it couldn't reach the netgear NTP server and router date time was mismatched, I set that up to a google NTP server
2- I reinstalled the latest firmware - just to make sure that it installs correctly (last time I updated the firmware, I didn't restart the router before the update - as indicaed in the readme for this firmware)
Lets see, if this still happens - will forget and add on all deviceslast resort would be to try and downgrade the firmware back to 1.08.x
- JWS9518Apr 15, 2020Luminary
Well, after dealing with this update the last few days, I am most likely going back to .42. I keep having various devices losing connection and then having a hard time getting them to reconnect to the network. I have had a few reboots as well, but that has not been the biggest issue. If I could just keep devices from losing the network and then refusing to connect back, it would not be so frustrating.
I really wish Netgear would get their act together on their firmware stability. Or at least issue guidance on what firmware works best, especially if there are differences with the devices in how they are manufactured.
- shoman94Apr 15, 2020ApprenticeYup I moved on. ... It was time.
