Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy: R7000 Firmware V1.0.11.100_10.2.100 Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0...
Bottz
Apr 18, 2020Tutor
After installing 1.0.11.100 my 2.4 and 5ghz would stop working daily. A hard reboot of the router would fix the problem temporarily. I ended up downgrading to .88. I'm also starting to hate this security software Netgear is pushing. Maybe it's time to move on..
- Portwey84Apr 18, 2020Virtuoso
It's entirely hypothetical, but the firmware issues might be affecting older routers disproportionately. From what users on this forum have indicated, these R7000 units have been made in different factories in different countries, some in China, some in Vietnam.
Just because one router looks identical to another doesn't necessarily mean that the components used inside are identical. Over the years, electronics and components change. I'd be surprised if a router made 5 years ago and one made within the last 12 months stripped down side by side, would be utilizing exactly the same electronic components. There have been advancements in WiFi tech and components over the years. Who's to say that the wireless components used haven't altered between batches built between 2014 and 2020? This may or may not have a bearing on whether firmware updates will have the same degree of success between identical models of different manufacturing years from different factories. Maybe this is the reason why my own router for example, isn't suffering any ill effects at all from the latest firmware update.
- iFrogApr 18, 2020Guide
Portwey84 wrote:It's entirely hypothetical, but the firmware issues might be affecting older routers disproportionately. From what users on this forum have indicated, these R7000 units have been made in different factories in different countries, some in China, some in Vietnam.
The fact there are routers like the R7000 that allow you to choose which OS to run on it, like you would any other computer is something I enjoy.
I may like the hardware spects of both a computer, or even a router in this case, but may have issues, or just not like the stock firmware/ os.
The issue I have with most consumer routers has mainly been, the quality of the hardware, and / or firmware / os.
In the case of the R7000 I first tried FreshTomato firmware, as suggested on this thread, but that wasn't a good fit, and I had issues with speed. So, I went back to DD-WRT, which I had run on my R7000 last year for several months straight. After going back, I regained great speed and stability, and because DD-WRT doesn't support WPS, I don't even have that functionality anymore to deal with, which was another ocmplaint here on this thread. At the end of the day, for me, I considder my issues resolved at no cost to me, other than time, to manually configure settings stock firmware either doesn't have, or try to do for you, and also reading about settings and how to set them.
With this said, I plan to do this the more professional way when I needs a physical new router, by getting a wired only router, and a seperate asccess point so I don't have to depend on one device for both, especially if there are wireless problems than it won't take down the whole network to fix. (At least, it shouldn't)
- BottzApr 18, 2020TutorI'm all for experimenting with 3rd party firmware. My issue is with Netgear sending out an official firmware update that hasn't been properly tested. Also, if Netgear has different hardware in different revisions of the r7000 then they should have made a different model number with different firmware all together. I guess I'm just frustrated beings that the wife and I are both working from home and rely on wifi. I just struggle to accept this result after installing an official firmware from the manufacturer that made the device, that's all I'm saying.
