Thornado
Apr 02, 2020Apprentice
New R7000 Firmware Version 1.0.11.100
It's been a while but finally NG has released a new firmware for R7000! :smileyhappy:
R7000 Firmware V1.0.11.100_10.2.100
Download: https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0-11-100
Security Fixes:
- Fixes security issues.
Bug Fixes:
- Fixes the issue where disconnected devices still display as connected after a period of time.
- Fixes the issue where the system default time displays as 2015 when the NTP sync up fails.
- Fixes the system crash or out of memory issue
- Fixes the issue where incorrect data displays under the attached devices list.
- Fixes the issue where devices under the attached devices list can’t be edited.
- Fixes typos in the GUI.
Both automatically update and 'Search for update' did not work. But downloading the .zip file and updating manually worked like a charm.
Bandwidth-test of my 200/200 line:
201.29Mbps | 201.34Mbps |
So far, so good. I will update post if meeting any issues or problems.
Happy quarantine time! :heart:
- Adel96AspirantHi There
I update my router to this update and I still experiencing WiFi drop off and no internet I have to restart the router to get WiFi working ?
Thank you - ErwinL2Aspirant
Hello,
I had problems with the 5Ghz always losing internet connection and updated the firmware now to V1.0.11.100_10.2.100 . Dit all according the manual , but I still am having the same problem, any ideas?
Quite annoying when working from home and being in a call almost all day. My wife and I are thinking of replacing the device because we can't keep on working like this
Thnaks for all the help I can get.
Kind regards,
Erwin
