jimbag8
Mar 14, 2022Guide
New R7350 Nighthawk downloading massive amounts of data
I recently purchased a NEW R7350 nighthawk router and installed it last month. I am now seeing 4x the data usage, which as I search the internet seems to not be a new problem. Netgear has no way to...
- Mar 15, 2022
does it happen on your other devices?
I know there was some issues with firesticks when they first come out downloading to much screensavers/wallpaper and burning through data.
Try your other devices to see if its just an issue on that firestick.
jimbag8
Mar 15, 2022Guide
Sorry...it was "off" (not streaming but on the home screen) for the night, but still plugged in and on network. There are no recordings scheduled on the device.
jim
Mar 15, 2022Guru - Experienced User
- jimbag8Mar 15, 2022Guide
Thanks planning to do that. One thing to remember is none of this was a problem on the old router. I need to go grab that from the other house and see what through put was permitted on each network. I have also throttled throughput on my 2 nets (5 Ghz and 2.4 Ghz to < 300Mbs).
A REALLY helpful thing would be if Netgear would figure out how to show device bw consumption. This is a guessing game otherwise, but I digress.
- plemansMar 15, 2022Guru - Experienced User
It would be awesome to have per device tracking on consumer devices.
Like you said, its one of the most frequent requests.
- jimbag8Mar 23, 2022Guide
thanks for the help. I appear to be back to normal on data usage. I wound up factory resetting all 3 firesticks, upgrading firmware in my ring doorbell, and leaving my Roku devices unplugged. I went from 100GB/day to 5GB/day.
