Praisehym
Jun 23, 2021Initiate
New R7450 AC2600
Normally, to preconfigured a router I can either wire via Ethernet from my PC Ethernet port to any LAN port and type the router address in a browser and login to configure the router. Is there a manda...
Praisehym
Jun 28, 2021Initiate
No error. I opened chat support feed and the person answering made that statement that we needed internet to configure the router. Sent a lot of instructions that supported that theory. Admittedly an internet connection would make it a little easier but, not having one doesn’t mean it can’t be done. I retired a few years back as a network engineer from HP. I’ve configured a lot of commercial grade routers and switches and, like you, I prefer to pre-configure then drop it in with little or no surprises. I got it going after getting my PC to set the router as my default gateway and observing how certain panels responded when moving around inside the router after restoring the firmware manually. Firmware was suspected to be corrupted. Thanks.
Jun 29, 2021Guru - Experienced User
glad you got it going
