REMALUFC
Jul 02, 2023Initiate
New router to replace Nighthawk AC1900 Model R7000
Hi .. router eventually died on me. Please suggest one of a similar ability.  I have fiber internet supplied to apartment ( approx 100 sq metres )at 100/10 speeds.  Just need router (believe no modem ...
- Jul 06, 2023Thank you all for the replies , sorry I've not responded till now.
I think I've decided on a competitors (model name is RT ax58u not to mention actual company)mainly due to price and availability here in Sweden. It's probably overkill anyway but when your not sure about the technical details like what a dual, Tri, or quad core processor at different speeds make to a modems performance, you tend to buy the most you can afford ,namely 1390 Swedish kronor.
Always find this forum friendly and helpful.
Cheers again everyone for contributing 👍🙂
Jul 02, 2023Guru - Experienced User
The R series routers are getting up in age. Mostly no longer available or might find something used.
RAX series is NG next generation of routers. AC and AX supporting.
Might look for something RAX## and look at the spec sheets to see what would be best fit.
I'd try something RAX30 and up to maybe a RAX50 if something is available in your region.
microchip8
Jul 02, 2023Master
I'm using a RAX43 since about 2 years now and have had very little problems with it. I bought it for about 160 Euro's with a discount. As FURRYe38 say, I'd leave the R series aside and go for the RAX ones.
