REMALUFC
Jul 02, 2023Initiate
New router to replace Nighthawk AC1900 Model R7000
Hi .. router eventually died on me. Please suggest one of a similar ability.  I have fiber internet supplied to apartment ( approx 100 sq metres )at 100/10 speeds.  Just need router (believe no modem ...
- Jul 06, 2023Thank you all for the replies , sorry I've not responded till now.
I think I've decided on a competitors (model name is RT ax58u not to mention actual company)mainly due to price and availability here in Sweden. It's probably overkill anyway but when your not sure about the technical details like what a dual, Tri, or quad core processor at different speeds make to a modems performance, you tend to buy the most you can afford ,namely 1390 Swedish kronor.
Always find this forum friendly and helpful.
Cheers again everyone for contributing 👍🙂
michaelkenward
Jul 05, 2023Guru - Experienced User
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
REMALUFC
Jul 06, 2023Initiate
