Gonzalez09
Oct 30, 2021Follower
New router trying to set up but asking for a password
Have a new router trying to set up but when I go to hook up to netgear router it aske for a password?? Help!!
usually has a sticker on back of the device showing the password
what router did you buy?
Are you trying to connect to it via wireless or wired?
If you're trying to set it up wired, the default login to the routers interface is
login: admin
password: password
That'll get you going on setup.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
