SaintJulio
Jun 21, 2022Aspirant
New to netgear
Im planning to get a netgear and have a couple questions. Does Netgear need a modem to work or does it work as soon you connect the coax cable from the wall to the netgear will it work? Do you have to...
- Jun 22, 2022
SaintJulio wrote:
Im planning to get a netgear and have a couple questions. Does Netgear need a modem to work or does it work as soon you connect the coax cable from the wall to the netgear will it work? Do you have to pay monthly like Xfinity for example?A Netgear what?
What is the "coax cable from the wall"? It may or may not need a modem, depending on what sort of Internet you get.
Ask your ##Internet service provider what equipment you need. It may offer to rent of sell you something. But most will let you use your own equipment
Xfinity is an ISP. All ISPs that I know of charge for access.
microchip8
Jun 21, 2022Master
Yes, it needs a modem.
No, you don't have to pay monthly. It's your equipment.
SaintJulio
Thank you so much for replying
Mind if i ask where i can buy a modem?
