SaintJulio
Jun 21, 2022Aspirant
New to netgear
Im planning to get a netgear and have a couple questions. Does Netgear need a modem to work or does it work as soon you connect the coax cable from the wall to the netgear will it work? Do you have to...
- Jun 22, 2022
SaintJulio wrote:
Im planning to get a netgear and have a couple questions. Does Netgear need a modem to work or does it work as soon you connect the coax cable from the wall to the netgear will it work? Do you have to pay monthly like Xfinity for example?A Netgear what?
What is the "coax cable from the wall"? It may or may not need a modem, depending on what sort of Internet you get.
Ask your ##Internet service provider what equipment you need. It may offer to rent of sell you something. But most will let you use your own equipment
Xfinity is an ISP. All ISPs that I know of charge for access.
SaintJulio
Jun 22, 2022Aspirant
Thanks for writing back
I had xfinity but recently changed to fios but canceled there service not to long agoi
Netgear i was planning to get was ac1900 router
michaelkenward
Jun 22, 2022Guru - Experienced User
You'll have to sign up with someone to get onto the Internet. I'd wait until I chose that before deciding what equipment to buy.
That's not a Netgear model number. AC1900 is not a unique Netgear model number. Some devices come with the AC tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
AC1900 is also a somewhat ancient wifi technology from about five years ago. Does Netgear still sell that stuff?
- SaintJulioJun 22, 2022AspirantLMAO okay what router do you recommend i should get
- FURRYe38Jun 22, 2022Guru - Experienced User
I would check out something RAX or maybe a MK MESH system. R series routers aren't being made anymore and will eventually be EoL.
- SaintJulioJun 22, 2022AspirantGot you thanks bro
- michaelkenwardJun 22, 2022Guru - Experienced User
SaintJulio wrote:
LMAO okay what router do you recommend i should getI would never recommend anything without knowing what you need. We don't all live at the bleeding edge
Go for the cheapest that fills the bill and meets your budget.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
