Mark-P's avatar
Mark-P
New WIFI connection showing up I did not add
I'm using the PC GENIE app and it shows a new WIFI connection (I assume my router is now transmitting) that I never added.  If I look at the WIFI Channels it shows up to.  The name given to the conne...
  • duckware's avatar
    Jan 17, 2020
    Sounds a Chromecast device that is failing to connect to your wifi.
