DePuy
Nov 05, 2020Aspirant
New WIFI Router Suggestions Switching from ARRIS SB 6190
Hi Folks, We have the ARRIS SB 6190 installed now and it constantly drops WIFI for all our iphones and TV;s It will run fine than we have to call Comcast for a reset and/or unplug and reboot almo...
Nov 05, 2020Guru - Experienced User
The SB6190 is a modem only device from arris. And its a fairly solid modem.
what router do you currently have?
Do wired devices drop at the same time or just wireless?
I'm just trying to figure out if it is indeed a modem issue or a router issue.
- DePuyNov 05, 2020Aspirant
Thanks for the help.
There are no wired devices.
The ARRIS connects to a eero device
- plemansNov 05, 2020Guru - Experienced User
Which eero device? The Eero's are pretty solid.
I'm not trying to push you away from netgear but it sounds like you have a solid modem and router
If you log into the modem's connections page (usually 192.168.100.1), it should show you the cable connections page and logs.
You can post them here and I can take a look at them to see if there's issues.
I'd also check to see if you have any cable splitters, attenuators, or amplifiers in line. That can effect your signal too.
thanks and i appreciate the help...
