newworld
Mar 09, 2022Aspirant
Newbie needs help to change IP address on Nighthawk
My router was installed (not by me) almost a year ago. Because I keep get bumped off Zoom on one particular device (a new Dell laptop), one suggestion I got from a friend who had a similar problem i...
- Mar 11, 2022
newworld wrote:
...one suggestion I got from a friend who had a similar problem is to change the (extension of?) the IP address.
Is this friend a network expert? That sounds like a strange suggestion..
Because I keep get bumped off Zoom on one particular device (a new Dell laptop),I'd forget about messing around with UP addresses and go back to basics. Work out why that happened.
What does "bumped off" mean? What happened?
You can run test sessions on Zoom to diagnose what is going on. Fix that ands you may be able to leave your router alone.
Mar 09, 2022Guru - Experienced User
what firmware is on the R7000?
What speeds Upload and download do you pay for?
Are you connecting your laptop to the 2.4ghz signal or the 5ghz?
2.4ghz is slower and more sensitive to interference.
- newworldMar 10, 2022Aspirant
I get speeds of 94.7 mbps download, 11.6 upload (just tested). Pretty sure the 2.4 signal. Not sure where to look for ID firmware or what it looks like.
I used the laptop on Zoom yesterday, and I got knocked off as soon as I Screen Shared. I do appreciate your hanging in there with me, since I am pretty clueless.
- plemansMar 10, 2022Guru - Experienced User
You still didn't answer the questions.
1. firmware on the router?
2. speeds you actually pay for? upload/download
3. band you're testing on? (pretty sure isn't an answer) You'd look on the device you're testing on
try hardwiring whatever you're using zoom on and see if it works hardwired
- newworldMar 11, 2022Aspirant
You are obviously losing patience with my inability to provide answers. I just do not know where to look, don't know where to find the answers to the Qs you ask, though it may seem obvious to you. I will look elsewhere for help. Thanks anyway.
