DaveLeitch
Jul 22, 2021Guide
Newbie question
Hi I want to force a device (Yamaha wx10 speaker) to connect on 2.4 and I'm using "smart connect". Is there any way to make that happen? At the moment the device is sometimes visible to Apple Air...
DarrenM
Jul 22, 2021Sr. NETGEAR Moderator
You could try to disable smart connect and then connect it to the band you want and then try enabling smart connect again. This may not work as smart connect decides what band to put each device on.
DarrenM
