DaveLeitch
Jul 22, 2021Guide
Newbie question
Hi I want to force a device (Yamaha wx10 speaker) to connect on 2.4 and I'm using "smart connect". Is there any way to make that happen? At the moment the device is sometimes visible to Apple Air...
Jul 22, 2021Guru - Experienced User
1. what modem/gateway are you using?
2. According to the manual, that speaker only supports 2.4ghz.
3. what firmware is on the router?
- DaveLeitchJul 22, 2021Guide
Hi Plemans
it is the latest/current version of the firmware for both the router and the Yamaha. I don't see how the gateway is relevant but it's a Sagecomm 5366 reading the label.
It is nice to confirm the speaker is 2.4 only, that is what I thought. I am becoming confident the issue is when the router puts it on 2.4 it works fine. Then from time time the router assigns the speaker to 5 ghz and it drops off.
so I think I should assign to 2.4 permanently but I want smart connect for everything else. Sigh it seems gadgets still aren't good enough to do what seems so simple conceptually. :-)
- plemansJul 22, 2021Guru - Experienced User
The speaker won't move to 5ghz because it doesn't have the capabilities.
You might have a double nat issue as that sagemcom is a modem/router combo device. It could be whats causing your airplay issues.
https://kb.netgear.com/30186/What-is-Double-NAT
Do you have the sagemcom in modem only/passthrough mode?
Or have you put the netgears IP address into the sagemcoms DMZ?
or you have put the netgear in access point mode?
There could be a double nat, I will check that out, but I doubt it's the issue. In any case to get rid of double nat do I turn dhcp off in the sagecomm? I get that the speaker won't do 5 ghz.
