DaveLeitch
Jul 22, 2021Guide
Newbie question
Hi I want to force a device (Yamaha wx10 speaker) to connect on 2.4 and I'm using "smart connect". Is there any way to make that happen? At the moment the device is sometimes visible to Apple Air...
DaveLeitch
Jul 22, 2021Guide
I see I have to put the Sagecomm into bridge mode. From memory it doesn't just have a direct way to do that. So I will need to work out what Bridge mode settings actually are. I remain of the view this is a minor issue and not the cause of the speaker disconnect.
DaveLeitch
Jul 22, 2021Guide
Well apparently the Sagecomm doesn't do bridge mode. That therefore was an opportunity to cut the Sagecomm out of the setup altogether so now the RAX 200 connects viat a FTTC box to the internet without any other cable modem. This is good as it must remove some overhead from the system, and it does indeed feel snappier. Will check whether it helps with the Yamaha speaker disconnecting.
