cenaq
Dec 27, 2020Aspirant
Newest firmware for Nighthawk r7900p V1.4.1.66_1.3.26?
I update the firmware for the R7900P Netgear router to version R7900P-V1.4.1.64_1.3.25 which was the latest on Netgear's website. After updating the firmware and restarting, the router said new firmw...
chrispo86
Dec 28, 2020Aspirant
I actually just noticed the same thing. Was troubleshooting one problem and noticed that the router said it had a firmware update, which I installed and I ended up with V1.4.1.66_1.3.26. After that I started having issues with remote management, it won't let me turn it on (this is the router at my parent's house), so I was going to reflash the firmware, but I can't find that version available anywhere for download.
isutherland
Dec 29, 2020Initiate
I too am having issues with remote management via the Nighthawk app. I just purchased my second NetGear extender that's supposed to cover 2200sq ft and noticed the update. I now wish I didn't apply it... I'm almost at the point where I'm going to factory reset everything and start over with all of my equipment.
I'd suggest holding until they sort this out.
- captinboondogglDec 29, 2020GuideSame issue - nighthawk app (2.7.2.19) on iPhone 12 doesn’t allow connection to router running V1.4.1.66_1.3.26. Worked fine before upgrade. Can login fine via http...
- mneJan 07, 2021Guide
I had the same problem with the Nighthawk app after upgrading the R7900 router V1.4.1.66. To resolve, I used the http interface to roll back to V1.4.1.64. Hoping Netgear is aware and will release a fix.
