cenaq
Dec 27, 2020Aspirant
Newest firmware for Nighthawk r7900p V1.4.1.66_1.3.26?
I update the firmware for the R7900P Netgear router to version R7900P-V1.4.1.64_1.3.25 which was the latest on Netgear's website. After updating the firmware and restarting, the router said new firmw...
isutherland
Dec 29, 2020Initiate
I too am having issues with remote management via the Nighthawk app. I just purchased my second NetGear extender that's supposed to cover 2200sq ft and noticed the update. I now wish I didn't apply it... I'm almost at the point where I'm going to factory reset everything and start over with all of my equipment.
I'd suggest holding until they sort this out.
captinboondoggl
Dec 29, 2020Guide
Same issue - nighthawk app (2.7.2.19) on iPhone 12 doesn’t allow connection to router running V1.4.1.66_1.3.26. Worked fine before upgrade. Can login fine via http...
- mneJan 07, 2021Guide
I had the same problem with the Nighthawk app after upgrading the R7900 router V1.4.1.66. To resolve, I used the http interface to roll back to V1.4.1.64. Hoping Netgear is aware and will release a fix.
