Daver68
Aug 10, 2021Tutor
Newest Firmware update
Installed the newest Firmware and it no longer showed attached devices and messed up access control reverted back to V1.3.2.134_10.1.66. Tried to call support and I was -9521 inl ine netgear have you...
Daver68
Aug 11, 2021Tutor
Sorry for the lack of punctuation, Yes the number was for netgear support and rolling back the firmware resolved the issue.
michaelkenward
Aug 11, 2021Guru - Experienced User
Daver68 wrote:
....rolling back the firmware resolved the issue.
Thanks for that. I will try it on my R7000P.
If it does the same thing, I will shout. There has been a spate of bad firmware from Netgear in recent months.
Did you see if a reset would fix the problem before you rolled back?
I see that the only change claimed is the usual bland "Fixes security issues".
Daver68 wrote:
Yes the number was for netgear support ....
How did you find the number? The only contact is via MyNetgear. No phone numbers are published. You contact them and they call you.
- michaelkenwardAug 12, 2021Guru - Experienced User
No other reports of problems so far.
It has not arrived on the update server yet. That is sometimes when things go mad here.
- sktn77aAug 12, 2021Virtuoso
Yep, connected devices are wrong and mostly absent. What else have they messed up?
DNS seems to be a popular target in some recent firmware updates.
Trouble is that Netgear releases these "updates" with one aim in mind and then insists on moving the goalposts as it removes things that people expected when they parted with their cash. They have ditched features like parental controls and DLNA to make room for Armor and Circle so that it can extract more money from punters.
Fortunately Netgear has yet to mess up the R7800, my workhorse router.
- ArcoQuiSep 05, 2021Aspirant
After the firmware update that messed up my router, I did, I reset it many times and would check back to see if Netgear had put out another firmware update to correct the bad update. They never did so I thought my router had gone bad.
