kczerniak
Mar 25, 2020Tutor
Newly purchased router. Can't connect to internet.
Hey everyone, Forgive me in advance as I am technically challenged. I just bought a Nighthawk hoping to boost my internet for Xbox and PC gaming. I followed the setup instructions step by step but ul...
- Mar 26, 2020Problem solved. I was able to get tech support on the phone. Ultimately had to "forget" the network and start from scratch. Thanks for everyone's efforts.
Mar 25, 2020Guru - Experienced User
supports getting crushed right now with the covid and everyone working from home.
What modem are you connecting to?
What firmware is on it?
did you boot in this order?
(first power off both devices and disconnect everything from them)
hook up modem to coax and then power. power it on. give it a few minutes.
then connect modem to router.
power up router and give it a few minutes.
Then try setup.
kczerniak
Mar 25, 2020Tutor
I'm hooking it up to the Arris modem from Optimum. And when I set it up it recommended a firmware update which I did. So I assume it's on the latest firmware.
As far as setup yes I followed those steps.
- plemansMar 25, 2020Guru - Experienced User
which arris modem? (model)
And if it was able to automatically update firmware, it did connect to internet.
Did you try factory resetting and re-installing?
- kczerniakMar 25, 2020TutorArris TM1602. It's whatever came with our Optimum service. I tried to factory reset but the power light stayed flashing for a very long time with no results.
Did the power light stop flashing?
What are the rest of the lights doing?
try factory resetting both devices and then following the boot up sequence.
