renzandjo
Sep 13, 2020Aspirant
NG Nhawk R6700 AC1750
Please help. I have NG NHawk 6700 AC1750 and I just tried to do the firmware update today 9/13 and the update would not complete and got errorrs and then I just lost all conectivity and it appearrs l...
- Sep 14, 2020
sounds like you might have corrupted the firmware. in the future, i'd recommend not using the app to update with. I'd use a hardwired computer.
for the present, you can try recovering it using tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Sep 14, 2020Guru - Experienced User
- renzandjoSep 14, 2020Aspirant
thanks for responding.
Can you give me these instructions for a macbook pro running safari, chrome or firefox?
- antinodeSep 14, 2020Guru
> Can you give me these instructions for a macbook pro [...]
https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] running safari, chrome or firefox?
A web browser is not really part of the TFTP recovery scheme.
If you have trouble, then it'd probably be better to start your own
thread with your own details.
Can you give me these instructions for a MACbook PRO running safari, chrome or firefox?
