Idekanymore
Jan 17, 2022Aspirant
NH R6900P Help
I moved about a year ago and stowed away my Night Hawk R6900P AC1900. I switched ISP's from Century Link (DSL) to Gateway Fiber (Fiber Optic) and finally got the router out. When I hooked it up, the ...
Jan 17, 2022Guru - Experienced User
a couple things.
1. what ont/gateway is the netgear connected to? (Model)
2. did the wifi on/off button get hit? push and hold it for 2 seconds.
- IdekanymoreJan 18, 2022Aspirant
I belive it is a Calix GigaPoint 803G. I could not find a WiFi button on the device. I'll take a look at the manual to see where it is located.
Thank you!
- plemansJan 18, 2022Guru - Experienced User
2nd button in from the right side. Looks like an led.
Nighthawk R6900P | AC1900 Smart WiFi Router | NETGEAR Support
