Lunacy1's avatar
Lunacy1
Night Hawk 6900v2 not getting my full speed
I run through fiber 1 G and it will not get the full G it actually gets around 500 MB I tryed shutting off the qos or whatever it stayed the same am I missing something I can do because I will not downgrade the firmware
  • FURRYe38's avatar
    What is the CAT# lan cable in between the ONT and router? CAT6 is recommended for 1Gb speeds on the wire.
    Are you speed testing with a wireless or wired device? Wired is preferred.
    Try a different wired PC to compare results.
    What speed testing app are you using? Ooklas installable speed test app is recommended.
    Has a factory reset and setup from scratch been performed since last update and setup with out Armor, SPC or Traffic Meter enabled?
    • Lunacy1's avatar
      Lunacy1
      I had to step out I can tell you details when I get back but the isp tryed everything they could to help get it to 1 G. it only got a 600 MB option but on a the 5G it got the option for for 1500 but won't go over 600 but the router they usually provide to costumers was pulling the speed both ways but I'm a fan of the night Hawks i really don't want to switch
