Larrynsc
Aug 16, 2020Aspirant
night hawk AC1900 model C7100V. Cable Modem Voice router
I am using a AC1900 C7100V nighthawk router. I am gettting amazing speeds on my wireless devices, I pay for 200 Mbps internet speed from WOW. Speed tests on my wifi Firesticks at 50 ft are running 1...
- Aug 17, 2020
What firestick has a wired connection? I know the fire cube and original fire tv box (not stick) had a wired connection.
If its using a usb/ethernet adapter, it might only be rated to 10/100mbps. So what adapter are you using for the firestick to connect.
Aug 17, 2020Guru - Experienced User
Larrynsc
Aug 24, 2020Aspirant
Thank you so much. that was it exactly. I connected an android box with out the ethernet and mt speed through the wired connection nearly maxxed out. I am searching for an ethernet adapter that does not throttle down the speed. Thanks
- plemansAug 24, 2020Guru - Experienced User
the firestick usb-rj45 adapters are usb 2.0.
And most streaming devices don't need more than 20-40mbps because 4k streams at around 40mbps max.
so why do you need more than the 100mbps connection if the firestick itself doesn't need a faster connection?
