Iamnotanumber
Nov 24, 2018Tutor
Night Hawk external usb
I connect my 2.5" USB to the X4S and I can see it in the modem config page
I type run and then type \\readyshare and hit the ok button
A window displays but I can't see the content of the drive i...
- Nov 24, 2018
What OS are you running, I assume Windows?
If you run NETVIEW, what do you see, copy and paste in your reply. Mine looks like this:
C:\>net view
Server Name Remark
\\IRV8700 Irv's 8700
\\READYSHARE readyshare
The command completed successfully.------------------------------
Windows key+R and entering \\readyshare works fine for me.
It could be a Windows Credentials problem or SMB1 being required? I need a credentail with the UID and PW of the router to access it as well as SMB1 running. Check for the Credential in the Control Panel to see if you have one. If you have protected the USB drive with a password you surely need that.
IrvSp
Nov 24, 2018Master
C:\>net view
Server Name Remark
- IamnotanumberNov 24, 2018Tutor
I use windows 10 I just rebooted the router and the USB is now showing up and all is working ok.... let's hope it stays that way.
thanks for your reply
