Gpink
Aug 27, 2021Aspirant
Night Hawk R6700 V3 losing internet and needing manual reset near daily
I have a Nighthawk R6700 v3. I have had nothing but issues with it since I have hooked it up. Customer service is zero help. It loses internet connectivity daily and requires a manual reset (pulling p...
saleem_safi9910
Aug 28, 2021Aspirant
I think you should
Gpink wrote:
I have a Nighthawk R6700 v3. I have had nothing but issues with it since I have hooked it up. Customer service is zero help. It loses internet connectivity daily and requires a manual reset (pulling power and plugging back in after 30 seconds) and the internet resumes normal activity like nothing happened. This happens 1-2 times per day. I have used other routers and none of them have this issue. We have Verizon as an ISP. Furthermore, the router will drop all devices and when the devices go to reconnect it requires the password but prompts the password is wrong (yet it is the correct password because it was the saved password that has been working). Reset the router again and it fixes this. The router also will allow certain things to work when it decides to drop internet. Frequently the internet will not work citing a DNS issue while online gaming and Alexa devices function with no interruption. I need help.
auto disconnect sittings of the reouter, it will be 10min, make it to NEVER or 120min
