Dferron
May 23, 2021Aspirant
Night hawk R700 keep disconnecting from the internet
My netgear R7000 started to disconnect randomly from the internet about 2-3 weeks ago. It is now hapening 2-3 times per week. My router is connected to a Helix (videotron) modem in bridge mode. The ...
May 23, 2021Guru - Experienced User
What actual helix is it?
You might try the newest firmware 1.0.11.122. Install that firmware, do a factory reset, and then during the install process, don't use a backup configuration.
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
- DferronJul 11, 2021AspirantAfter updating to V1.0.11.123_10.2.100 it worked for a week and half but then the problem came back. I’ve noticed today that even if the router says it’s offline and devices cannot connect to the internet, it still ping, upload and download..
I’m a bit tired of restarting the router every 2-3 days and thinking about changing the router.
