EHerr
Jun 05, 2022Aspirant
Night Hawk R700 QoS= slow download speed
I play games on my PC, so having stable ping is preferable. Having good download speed is also awesome to have, as I need to frequently update some games or download others. The problem is that I hav...
- Jun 08, 2022
Enabling QoS, especially on older routers, always slowed down or caused the speed to have a overhead cap. I think as time went one QoS got some tuning in this area however it has mostly always slowed bandwidth speed results. Nature of the beast.
You can either use it or not use it or you might consider getting in to something different. Maybe an actual Gaming router since you seem to be a gamer. 🤖
Jun 05, 2022Guru - Experienced User
How are you speed testing? Wired PC and routers web page or external speed test app?
Is Armor, Circle or Traffic Meter enabled?
- EHerrJun 07, 2022Aspirant
Sorry about the late response!
Firmware VersionV1.0.9.88_10.2.88I believe that the manufacturer of my modem is Arris, and the model is Arris Surfboard SB6183.I am speed testing through speedtest.net, by Ookla. It tells me both my upload and download speeds.Armor shouldn't be enabled, as I haven't set it up or created an account for it.Traffic meter is disabled.- FURRYe38Jun 07, 2022Guru - Experienced User
What speeds UP and Down do you pay for?
Your using older FW as well:
I pay for 200 mbps download and 10 mbps upload. With QoS on, my 10 mbps upload stays the same, but my download goes down from 200 mbps to around 10 mbps.
I'll check out that firmware link you sent and see if I can't update it.
