tbejot
Oct 20, 2022Follower
Night Hawk R7000 AC2300 setup issues
This 'might' help someone. I had the above router. The cable modem was reporting good internet and confirmed with a computer via Ethernet. Whenever I tried to set up the router, the internet did not work and connecting via wireless was impossible.
I did a hard reset - went through the usual setup and everything looked ok (internet and wireless) then in the middle of connecting my apple tv's, lost internet and then lost the wireless.
I had to do 2 more hard resets before it finally worked. I was able to do the setup via the app. The only difference on the last setup via the app was the app reported the firmware was updated.
I think it was in the middle of the firmware update and this is why I lost internet. Apparently there is no - Yes update the firmware option so it does it automatically. Unfortunately you lose internet while the firmware is either downloading or when the router is updating the firmware and you just need to be patient.
Took about 4 hours to figure that out. :((
1 Reply
You can always skip the FW update during the setup process and manually update FW later on which would be recommended:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
