km414
Jul 13, 2021Aspirant
Night Hawk R7000 firmware update issue
We are having the same issues as others. Router drops at least once per day at around the same time. The App states the firmware is up to date, but from doing searches I have found we are way behin...
antinode
Jul 14, 2021Guru
> thanks, I think... [...]
You're probably welcome.
> My issue is with the App [...]
The app comes from the same organization which brings you buggy
router firmware.
If your goal was to complain about the app, then you might want to
include such a complaint in your posting. A subject like "Re: Night
Hawk R7000 firmware update issue", which does not mention the app, might
be sub-ideal for that purpose.
DarrenM
Jul 14, 2021Sr. NETGEAR Moderator
I believe we released a hotfix for the R7000 that will not show up on the auto update so you would need to manually install that firmware. You can find that firmware here
https://kb.netgear.com/000063684/R7000-Firmware-Version-1-0-11-123-Hot-Fix
DarrenM
- antinodeJul 14, 2021Guru
> the auto update [...]A little time spent perusing these forums might find many users who
claim that anything after V1.0.9.88_10.2.88 "will not show up on the
auto update". A search for something like "1.0.9.88" might be a good
start. One (month-old) example (out of many instances): - Portwey84Jul 15, 2021Virtuoso
DarrenM wrote:I believe we released a hotfix for the R7000 that will not show up on the auto update so you would need to manually install that firmware. You can find that firmware here
DarrenM
With much respect because clearly this doesn't seem to be sinking in, as antinode has also pointed out, this has been a problem for some time. Bearing in mind that v1.0.9.88 is now 5 firmware updates behind the latest hotfix release, someone within the firmware development team needs to look at the issue and sort it out. I don't think the auto update feature has ever worked on my own router since purchase loaded with v.64.
I also don't understand why Netgear keep pushing the Nighthawk App as the go to solution for updating firmware. I would personally never update wirelessly. Ending up with a borked router because the firmware update fails halfway through due to a dropped wireless connection, is a nightmare.
I'd like to point out again, for the umpteenth time, I personally don't have, nor have I ever had, any problems with my R7000 AC1900 router or firmware updates. I'm sure this isn't just down to luck!
