oochow69
Mar 28, 2024Follower
Night Hawk R7000
A few months ago I lost connecting to my Router. I can get to it on the APP but, it says its offline. I can't log into it directly either. Is it toast? I still have WiFi in home but that gets sket...
michaelkenward
Mar 29, 2024Guru - Experienced User
Connecting what?
Then the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
