firestorm31
Dec 20, 2018Aspirant
night hawk R7000p firmware upgrade failure
OS is Windows 10. I noticed that the nighthawk R7000P AC2300 had an firmware upgrade notice. the upgrade was for the 1.3.1.44 version.
I don't remember what the old version was , I know the las...
- Dec 21, 2018
jetspeedz wrote:
tftp the firmware its not hard
Nor is it that easy:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Further guidance is out there in Googleland.
jetspeedz
Dec 20, 2018Luminary
michaelkenward
Dec 21, 2018Guru - Experienced User
- myerswDec 21, 2018Master
If you want even more fun do the tftp procedure on a MAC laptop. Need Ethernet USB dongle to start with. :smileyhappy:
- firestorm31Dec 22, 2018Aspirant
that link did the trick.
some of the other tips weren't clear or confusing on where to go to change the IP address.
that document could be a little bit more clearer on the setting of the TFTP IP address and on which router port to use during TFPT; that part wasn't clear also.
thanx.
- michaelkenwardDec 22, 2018Guru - Experienced User
Not sure which link you mean – you haven't marked the relevant message as Solved – but it is hard to disagree with this bit:
that document could be a little bit more clearer on the setting of the TFTP IP address and on which router port to use during TFPT; that part wasn't clear also.TFTP isn't meant for amateurs like us. But it can be the only way out of a hole.
Glad it worked out in the end.
