firestorm31
Dec 21, 2018Aspirant
night hawk R7000p firmware upgrade failure
OS is Windows 10. I noticed that the nighthawk R7000P AC2300 had an firmware upgrade notice. the upgrade was for the 1.3.1.44 version.
I don't remember what the old version was , I know the las...
- Dec 21, 2018
jetspeedz wrote:
tftp the firmware its not hard
Nor is it that easy:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Further guidance is out there in Googleland.
michaelkenward
Dec 21, 2018Guru - Experienced User
firestorm31
Dec 22, 2018Aspirant
that link did the trick.
some of the other tips weren't clear or confusing on where to go to change the IP address.
that document could be a little bit more clearer on the setting of the TFTP IP address and on which router port to use during TFPT; that part wasn't clear also.
thanx.
- michaelkenwardDec 22, 2018Guru - Experienced User
Not sure which link you mean – you haven't marked the relevant message as Solved – but it is hard to disagree with this bit:
that document could be a little bit more clearer on the setting of the TFTP IP address and on which router port to use during TFPT; that part wasn't clear also.TFTP isn't meant for amateurs like us. But it can be the only way out of a hole.
Glad it worked out in the end.
