ChopperWhopper
Jun 14, 2021Follower
Night Hawk R8000 Blocking *.MIL Web Sites
Cannot access ANY *.MIL web sites using home wifi. All other domains are accessible (including *.GOV). I've been able to access *.MIL sites since 1999. This JUST STARTED the evening of 10 June 21....
Murrs700
Jul 06, 2021Aspirant
Hey, so above. Go into the router setting and disable the routers Firewall settings. They did change something, likely in an effort to get people who want it fixed to pay for it. That has worked for me so far. If they change something else I will just get a new router. This will definately be my last Netgear product for sure though. Them trying to charge us to fix a problem they made is actually criminal.
- michaelkenwardJul 07, 2021Guru - Experienced User
What Firewall setting?
There are none that I can see.
- Murrs700Jul 07, 2021Aspirant
See attached. Going on three days and still working fine.
