Lumo
Aug 02, 2021Follower
Night hawk Router AC1900 Model R7000 with Extender EX6110
Hi, I have become the resident house IT person due to Covid lockdown (meaning I am out of my depth most of the time). I have a Nighthawk router R7000 located upstairs in my office. Due to Cov...
- Aug 03, 2021
Block walls are great at blocking wifi.
I'm not surprised you're having issues with a stable signal through those walls.
Even going to an EAX80 isn't going to change much as the basic transmission power of routers/extenders hasn't changed with new standards (actuall decreased with 6E). They've just gotten a little more sensitive and able to operate better on a lower signal.
And the EAX80 is quite expensive.
If you need to get something through 2x brick walls, a better bet might be to check into a powerline setup with a wifi access point like the PLW1000. Or to use a moca adapter (ethernet over coax) to get through the walls.
Aug 03, 2021Guru - Experienced User
- sktn77aAug 03, 2021Virtuoso
Get the WiFi Analyser app on your (android) phone or windows computer and read the signal strengths directly at the different locations.
- michaelkenwardAug 03, 2021Guru - Experienced User
Good thinking.
Get as much evidence as possible, and play around with what you have now, especially before you splash out on an expensive Mesh extender.
