Lumo's avatar
Lumo
Follower
Aug 02, 2021
Night hawk Router AC1900 Model R7000 with Extender EX6110
Hi, I have become the resident house IT person due to Covid lockdown (meaning I am out of my depth most of the time). I have a Nighthawk router R7000 located upstairs in my office.     Due to Cov...
  • plemans's avatar
    Aug 03, 2021
    Block walls are great at blocking wifi.
    I'm not surprised you're having issues with a stable signal through those walls.
    Even going to an EAX80 isn't going to change much as the basic transmission power of routers/extenders hasn't changed with new standards (actuall decreased with 6E). They've just gotten a little more sensitive and able to operate better on a lower signal.
    And the EAX80 is quite expensive.
    If you need to get something through 2x brick walls, a better bet might be to check into a powerline setup with a wifi access point like the PLW1000. Or to use a moca adapter (ethernet over coax) to get through the walls.
