PJSaaf's avatar
PJSaaf
Night Hawk Security
Net gear sent an email about an action alert.   New software needs to be installed on my Night Hawk.  The admin username or password they have does not match what I have so I can't update the softwar...
  • JamesGL's avatar
    Jul 26, 2017
    Hi PJSaaf,
    Did you change the password before? The default username is admin(cannot be changed) and the password is password. If you cannot remember, then you may reset the router.
