PJSaaf
Jul 24, 2017Aspirant
Night Hawk Security
Net gear sent an email about an action alert. New software needs to be installed on my Night Hawk. The admin username or password they have does not match what I have so I can't update the softwar...
- Jul 26, 2017
Hi PJSaaf,
Did you change the password before? The default username is admin(cannot be changed) and the password is password. If you cannot remember, then you may reset the router.
JamesGL
Jul 26, 2017NETGEAR Employee Retired
Hi PJSaaf,
PJSaaf
Aug 06, 2017Aspirant
Pushing the reset button isn't doing anything. The power button stays white regardless of how long I hold the paper clip against the reset button.
- JamesGLAug 13, 2017NETGEAR Employee Retired
Hi PJSaaf,
How about other lights? Did they turn off when the reset button was pressed?
