Rich-Hatch
Dec 07, 2021Aspirant
Night Hawk X6 R8000 AC3200 Firmware Upgrade Causing New Problem!
After upgrading to the latest firmware release two days ago, I try to go to any websites that I haven't been to before or haven't been to in a long time like "gearhead.netgear.com", I have to refresh...
Dec 07, 2021Guru - Experienced User
what firmware version are you on?
Is IPv6 enabled? (try enabling it if not)
Rich-Hatch
Dec 08, 2021Aspirant
I'm on firmware version V1.0.4.76_10.1.82.
1) I guess I'm not connected to IPv6. See below:
2) Do I need IPv 6? I didn't need IPv6 before firmware upgrade.
Do I Need IPv6? I didn't need IPv6 before firmware upgrade.
- plemansDec 08, 2021Guru - Experienced User
I'd try enabling it. It then has the router use the ISP's IPv6 dns server and that can sometimes help.
If it doesn't, then try the downgrade.
- ValkreyDec 30, 2021Initiate
If you haven't already figured it out by now, it is the latest firmware on your Nighthawk that is causing your problem. I had the same issue a few months ago so I rolled back to version 1.0.4.68 and have had zero problems.
