Useruseruseruse
Mar 17, 2022Initiate
Nightgear R8000
I was able to see and control the phones connected to the Router but not I can't see anything as of a phone IOS or Android. I used to be able to see them in the GUI but not now. This all started when...
Mar 18, 2022Guru - Experienced User
If you want to try to fix it without a reset, you can try downgrading the firmware a version to see if thats what caused the issues.
Otherwise I would try a factory reset.
Useruseruseruse
Mar 18, 2022Initiate
Thank you for the help I do appreciate it. I thought about that but I don't see on Netgears website a lower firmware version?
- plemansMar 18, 2022Guru - Experienced User
Click on downloads--->+view previous versions
