ivan_pinatti
Nov 22, 2021Aspirant
Nighthark X8 AC5300 - Several Blinking Lights (Not working at all)
Hello everyone, I am trying to find some help to fix the problem the router. I've researched everywhere but couldn't find a problem similar to this one. One day it simply stopped working and st...
Apr 19, 2022Guru - Experienced User
What does the user manual say for the LEDs?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter.
Have you tried this version of FW yet?
ivan_pinatti
Jul 11, 2022Aspirant
Answers in italic and blue
What Firmware version is currently loaded? I don't know since the router is completely inaccessible.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It is not connected to anything and blinks the same
What does the user manual say for the LEDs? It doesn't
Any Wifi Neighbors near by? If so, how many? None, the router doesn't show any Wifi networks and the cable also doesn't work.
Armor, Circle, Traffic Meter. I can't as the system doesn't boot up.
Has a factory reset and setup from scratch been performed since last FW update? Yes, I tried several times. And if there was an update it did it by itself, in addition, it was plugged to an UPS, so I am discarding that it got corrupted due to a power outage.
I can't as the router is completely inaccessible.
Any other ideas?
- FURRYe38Jul 11, 2022Guru - Experienced User
Try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflash- ivan_pinattiDec 11, 2022Aspirant
Finally I had the time to try your recommendations FURRYe38. Unfortunately, it didn't work.
I've tried to use tftp on Windows 10 and 11, and also the nmrpflash through Linux. No luck on any of them.
One thing that I noticed is that ports 1,2, and 3, it doesn't get a stable network connection, they keep connecting and disconnecting. Only ports that get a stable connection are 4, 5, and 6, and they blink white when they do.
No luck also trying using the IP range 192.168.0.x. All the recommendations had the 192.168.1.x.
If you check the video, you will see that the ports 1,2, and 3, keep blinking that amber colour.
Any other ideas?
netgear support might have a clue about the blinking pattern. This probably has an error code with a possible solution in the internal documentation. Could you please help and advise?
#AC5300
#R8500
#NighthawkX8
