Blissful1
Nov 15, 2022Aspirant
Nighthaw7800 Firmware Update Links NO LONGER Work on Netgear Site
Hi~ I have some neighbors that are using my router for their internet access. I'm attempting to lock down my router and network but found I need to update the firmware for my router. I attempted to ...
- Nov 15, 2022
Yeah, I already changed the password. Unfortunately, I believe they accessed my router (via admin account) prior to changing the user password. Yes, I know I was lazy and should have locked down my network prior to the invasion. :')
My admin account password had been changed so I had to reset and set up my router network from scratch (at least that is what I suspect happened).
Anyway, thanks for the suggestion - I was very stupid and lazy with my network access and paid the price.
Blissful1
Nov 16, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
